Hi there,
I'm starting as a devops engineer in a company that uses the magic leap hub, i'm trying to automate the installation on windows machines, using saltstack, so the unattended option looks like what I need, but unfortunately when I launch the executable like this :
"C:\temp_dir\sbin\ML_Hub_Installer.exe" --mode unattended
It gives me an error as in :
There has been an error.
Unable to copy file
I run this command from an administrator terminal on windows 11.
Any ideas ?
Thanks
Unfortunately Salstack falls outside of our realm of support. I recommend reaching out about this issue through their support channels. It would also be helpful to get logs from the installation.
- output_loglevel: debug
Things to also check:
- Ensure administrator permissions.
- Use a simple file path (e.g., C:\MLHubInstaller).
- Disable antivirus/security software temporarily.
- Check for file locking (reboot if necessary).
Thank you for your answer, of course my question was not about the salt part
, I can handle this part, it was more about the correct way to get a cli syntax to actually get an unattended installation, but I figured it out, adding the path for installation was enough, as in :
"C:\dir\temp\ML_Hub_Installer.exe --mode unattended --prefix "C:\dir\MagicLeap"
Thank you for your quick answer
