Prefab Too Small Marker Tracking Unity
I am using the Marker Tracking Example but with a different prefab. However, the prefab size is being transformed to fit within the marker. How do I change the size of the prefab to expand outside of the marker?
Unity Editor version: 2022.3.31f1
ML2 OS version: 1.7.0
Unity SDK version: 1.7.0
Hi @faziz
Welcome to the forum. If you want to change how scaling works in the marker tracking example you should look at the last few lines where it says
if (marker.transform.localScale.x != markerSize)
       marker.localScale = new Vector3(markerSize, markerSize, markerSize);
You could disable this section in order to not scale the prefab to the marker size, or if you do still want scaling, just make sure that the prefab you are using is the appropriate size when scaled to Vector3.One.
-Sidney
