Marker Tracking Example Scene Problem
ML2 OS version: 1.4.0-dev2
MLSDK version: 1.11.0
Host OS: Windows 10
I have a problem with the SDK Example Scene "Marker Tracking" ( Marker Tracking | MagicLeap Developer Documentation )
This are my setting in Unity:
Screenshot 2023-11-04 114609
And this are my Marker settings:
Original AruCo
Marker ID: 1
Marker size: 50
Wenn ich den Code mit der ML2 angucke, passiert nichts außer dass auf dem Status UI folgendes erscheint:
Screenshot 2023-11-03 161336
Hi @athanasios.melenikiotis,
Thank you for raising this issue. Are you receiving any error logs in the console? Is this using the App Sim or a full build?
Additionally, you may want to check that the marker you are looking at is the same size as specified in the Unity inspector. Based on the screenshot you may have entered that the QR code is 50 meters wide, which would cause a notable offset between the actual marker and the one you scanned, and the marker could be appearing beyond the far clipping plane.
Yes. This was the problem Thank you.
