Could you please confirm whether Magic Leap 2 can directly provide the following data in the device/head coordinate frame?
Left eye position
Right eye position
Left eye rotation
Right eye rotation
Fixation/vergence position or direction
3D gaze position or direction
In particular, does DeviceCenteredEyeData.LeftEye and DeviceCenteredEyeData.RightEye provide the left/right eye pose directly relative to the Magic Leap headset/device frame?
For each of the quantities above, could you also clarify:
the recommended API/property to use,
the reference frame in which the value is originally reported, and
whether it can be obtained directly in the device/head frame?
Is there also a direct API/property for obtaining fixation and 3D gaze position or direction in the same device/head coordinate frame?
Magic Leap 2 provides access to per-eye pose and gaze data through the Unity Input System (via OpenXR / Magic Leap Unity SDK) and the underlying XR_ML_eye_tracker extension.
Magic Leap eye tracking data does not report raw metrics directly in the local physical headset device frame by default. Instead, Unity’s Input System reports eye poses in Unity’s World/XR Local Origin frame (or the tracker’s reference space). However, you can convert all eye and gaze values directly into the headset/device frame by multiplying them by the inverse matrix of the Main Camera / XR Head Pose transform.
DeviceCenteredEyeData.LeftEye and RightEye (or the EyeTracker device layout in Unity) provide eye pose data relative to the active XR Origin/Tracking Space, not as a fixed static offset relative to the raw device origin.
