WebXR reference space : 'unbounded' not supported issue
navigator.xr.requestSession('immersive-ar').then((session) =>
let refSpace = await session.requestReferenceSpace('unbounded');
This gives me the following error in the Magic Leap 2 browser:
VM8 ARCubes.js:82 Uncaught (in promise) DOMException: Failed to execute 'requestReferenceSpace' on 'XRSession': This device does not support the requested reference space type.
I understand from the Magic Leap documentation that the following reference spaces are supported (see WebXR | MagicLeap Developer Documentation) :
  • WebXR reference spaces (view, local, local-floor, bounded, unbounded)
    (note : view should be viewer).
So what am I doing wrong?
Thanks in advance,
Hi @andy.willems,
Would you mind sharing your ML2 OS version?
I have reached out to our team regarding this issue and I will report back to you as soon as I learn more.
Hello El,
Thanks for your response
I did an OS update just yesterday to see if that helps (it didn't).
Today I am working from home, I will give you the exact ML2 OS version tomorrow.
Kind Regards,
Andy
The OS version is : 1.4.1
Build number : B3E.230928.10-R.098
Hi @andy.willems,
Only viewer and local reference spaces are defualt and can be used without any request. For all other reference spaces, the application needs to specify explicitly when recoding a session. So instead of
it should be:
navigator.xr.requestSession('immersive-ar', { requiredFeatures: ['unbounded']}).then((session) =>
Hmm, did not know that. It will take a while before I can test.
Thanks!
Andy
Thanks, this fixed the error:-)
