Hello, I have recently purchased an ML2.
I am attempting to test and verify support for the Raw Camera Access module for development. So far I haven't been able to get it to work with the ML2. I've tried the following links but i get an error stating The specified session configuration is not supported.
example 1
Example 2
Is there an example or place where I can verify that this feature is working? Is there a setting on the device I need to change to enable support?
thank you
Happy to have you developing on the Magic Leap 2.
We support the WebXR Raw Camera Access module. You can learn more information using the following links :
Hi, Iām working on a research project where we use Varjo XR headsets and we process the video pass-through from the headset cameras in various ways before presenting it to the user in real-time. For now, we are using the Video Post Processing API...
Reading time: 2 mins š
Likes: 3 ā¤
https://immersive-web.github.io/raw-camera-access/
To test the functionality see the following example
https://storage.googleapis.com/chromium-webxr-test/r1255390/proposals/camera-access-barebones.html
system
Closed
November 19, 2024, 6:44pm
3
