Unity setup issue for magic leap 2
Unity Editor version: 2022.2.12f1
ML2 OS version: Version 1.4.1
Build B3E.230928.10-R.098
Android API Level 29
MLSDK version: v1.12.0 (Couldn't install)
Host OS: Windows 11
Description:
  1. Approach1: I am following the ML2 Installation tutorials and getting below error when trying to add the unity sdk.
  2. Approach2: Magic Leap setup tool returns 404.
    Asset Store (unity.com)
I am unable to get started with the development. If anyone could direct me towards working tutorial for setup and getting started with ML2 unity development, it would be great.
[Package Manager Window] Error adding package: file:C:/Users/USER_NAME/MagicLeap/tools/unity/v1.12.0/com.magicleap.unitysdk.tgz. An error occurred, likely on the server. Please try again later.
Unable to add package [file:C:/Users/USER_NAME/MagicLeap/tools/unity/v1.12.0/com.magicleap.unitysdk.tgz]:
One or more dependencies could not be added to the local file system:
com.unity.xr.magicleap: Request [GET https://download.packages.unity.com/com.unity.xr.magicleap/-/com.unity.xr.magicleap-7.0.0.tgz] failed with status code [502]
UnityEditor.EditorApplication:Internal_CallUpdateFunctions ()
Hi @chandrashekar2,
I have reached out to our team regarding this issue and I will report back as soon as I learn more. Thank you for the detailed description as it helps us track down the issue.
Hi @chandrashekar2,
Would you mind signing out of your Unity account and singing back in again. It looks like your package manager can't connect to the network.
Hello etucker,
I was able to do the unity setup and test out few example scenes built in the ML toolkit. I no longer face the issue with magic leap unity setup.
Thanks for the amazing product.
