Trying to set up Unity to use the ML Development Kit, when setting it up initially I think I accidentally selected the wrong SDK folder, and now the Magic Leap Setup Tool is just loading forever. I have tried on multiple versions, removing and re-adding, re-installing unity, etc.
Unity Editor version: 2022.3.19
ML2 OS version: None
MLSDK version: 1.5.0
NullReferenceException: Object reference not set to an instance of an object
UnityEditor.XR.MagicLeap.MagicLeapProjectValidationRulesSetup.HasMagicLeapPackageVersionChanged (UnityEditor.PackageManager.PackageRegistrationEventArgs packageRegistrationEventArgs) (at ./Library/PackageCache/com.unity.xr.magicleap@7.0.0/Editor/MagicLeapProjectValidationRulesSetup.cs:44)
UnityEditor.XR.MagicLeap.MagicLeapProjectValidationRulesSetup+<>c__DisplayClass2_0.b__1 () (at ./Library/PackageCache/com.unity.xr.magicleap@7.0.0/Editor/MagicLeapProjectValidationRulesSetup.cs:31)
UnityEditor.EditorApplication.Internal_CallDelayFunctions () (at <2acbecbc299e4654adc94df891af51f2>:0)
