Simulator Environment
I am not able to get the Magic Leap 2 device so I'm trying to test my app in the simulator. Is there any way to change the simulator environment or create one?
there is a scene view on the bottom left from there you can change the environment. there are a few additional scenes you can load that are supplied using the add room button at the top of the scene graph
the office is the stock and if you open the dropdown you can change and delete/add to your hearts content
Great :sunglasses::eyeglasses:. Thanks this helped. :sunglasses:
