Application Simulator Plug-in for Unity Editor
Hi there,
Fact : The Magic Leap App Simulator is no longer being developed or supported.
Following the official web page, the solution should be straightforward :
"The Application Simulator for Unity is an offering that is separate, but related to the Application Simulator. Previously, it was recommended to use the Application Simulator through the Magic Leap Hub (ML Hub), but due to performance and compatibility reasons, it is now recommended that you follow the steps outlined on this page rather than starting the Application Simulator in the ML Hub, switching to Unity, and clicking Play."
Unfortunately, I'm not able to find/download the Application Simulator Plug-in for Unity Editor !? (I tried to dowload the package through ML Hub 2, and ML Hub 3)
Any idea ?
Jean-Luc :slight_smile:
Hi @Zoubi It looks like the package shifted since the guide was first written.
Here it is inside the ML Hub 2
However, I would suggest to use the XRI simulator instead since the Magic Leap App Simulator for Unity does not support OpenXR applications and may not work as expected.
