Questions about AR Cloud
I have a question about AR Cloud, should I ask it in a Github Issue instead of this forum?
I have already asked the question in Issue.
I thought you left out the explanation of the setup around GCP that is done before setting up AR Cloud.
I don't think it is necessary to explain from the GCP installation, but I think it would be better to post any links that would be helpful.
It seems to me that it will take rather long to set up AR Cloud.
Thanks.
Sadao Tokuyama
https://twitter.com/tokufxug
Thank you for your post @tokufxug. I'm echoing our Issue response here, please tell me if this helps you:
Please see this example env.example
