Open xr unity feature group
which version of Interaction Toolkit is recommended
I am getting issue with xr hands pre and stable Interaction tool kit
Please see if the Magic Leap Inputs work correctly when referencing them directly. If you are using the Magic Leap Input Asset, remember that the asset needs to be enabled before it is able to query data. You can also try to use the following script
