Magic Leap 2 Overheats and Crash
Device is crashing my application during the middle of the application, particularly when changing scenes in Unity. I believe this is the result of overheating as the device's fans ramps up after finishing the loading of the next scene.
Unity Editor version: 2022.3.31f1
ML2 OS version: 1.7.0
Unity SDK version: 1.7.0
Do you mind providing logs and profiling information and possible reproduction steps. It will be hard to assist you if we cannot reproduce the issue ourselves.
Does the issue occur with less resource intensive applications? Have you tested adjusting the battery settings in the Device's System Settings?
