In my headset, the left eyes top left corner is darker than the right eye top right corner. This happens immediately after the Magic Leap loading screen. Is this just inherent in the dimming system?
Hi @rob42lou,
This is occuring at all times that the headset is on? It occurs on all applications?
Yes it does, for all applications and even on the Magic Leap 2 main menu.
Is this darkness visible in screenshots? I'm assuming it's a hardware issue so it's not visible.
I am going to reach out to our customer care team to let them know you're having this issue with the headset.
It is not visible in screenshots unfortunately, thanks for your help!
Hi Rob,
Are these symptoms emergent or were they always present in your Magic Leap 2? Is it dramatically different or simply noticably different?
Thank you,
I believe they are new since the July update.
What OS version are you on currently?
The most recent version that came out last week
Hi Rob,
Could you please specify the actual version number?
Thankl you,
Sure, it's OS version 1.3.1(secure)
Hi Rob,
Sorry we didn't get back to you sooner. Are you still experiencing this issue? Were you able to update to 1.4.0 and see if that resolves it?
Thank you,
Hi Rob,
Just wanted to follow up on this and see if the latest update resolves the issue for you.
Thank you,
