Importing Vuforia Engine
While importing Vuforia Engine v11.3.4 I get this error.
Probably the problem is related to change made in ARFoundation package.
I tried to change AR foundation version to 4.2.8 which is recommended for Vuforia but it is upgraded to 5.2.0 automatically due to “some other package depends on it”. I want to use Vuforia for body tracking in MagicLeap2. If there is a way to fix this problem or to make body tracking in any other way then please share it with me.
Unity Editor version: 2022.3.61
ML2 OS version: 2.6.0-pre.R15
Library\PackageCache\com.ptc.vuforia.engine@961073a467cc\Vuforia\Scripts\Internal\ARFoundationIntegration\ARFoundationFacade.cs(253,31): error CS0246: The type or namespace name ‘ARTrackablesChangedEventArgs<>’ could not be found (are you missing a using directive or an assembly reference?)
