How to disable the controller standby mode?
I am creating an application where a robot is using the magic leap 2 controller and trying to draw lines in space. Is it possible to disable the standby mode of the controller?
Controller stops tracking after 3 seconds if there is no change in position and rotation and only get activated if the controller is rotated more than 5 degrees and moved a bit. This is written in the documentation. But robot sometimes stands still for more than 3 seconds and my experiment is ruined.
Any help will be appreciated?
Hi @jeswin1995 could you tell us more about your application so I can pass this information along to Voice of Customer. Currently the controller movement is used to detect if the World Cameras should track Hands and Controller or if they should switch to a faster hand tracking when the controller is not active. Because of this, preventing the controller from going to sleep would result in reduced accuracy of hand tracking and decreased battery life.
