Remove the Magic Leap 2 HMD from your head and after a short while, you will lose tracking
When the HMD is removed from the head, the image on the HMD will be reproduced in some cases, but in other cases the tracking will not work. The HMD can be removed and the image projected on the HMD cannot be captured by the smartphone's camera. Last year's OS version worked fine. I would like to see this issue resolved if possible.
ML2 OS version :1.2.0 B3E.230330.11-R.044
I was seeing this same behavior too. I think it is due to Standby mode. You can disable it by going into Settings > Battery. Then disable Compute Pack Standby.
