Double Clicking From The Controller In Our Magic Leap 2 Application
Hello Magic Leap 2 Support Team,
The controller 'double clicks' everything - causing issues. The controller works fine 'outside' of our application - just has issues when in our application. Obviously, something changed with the OS update. It double clicks sometimes and does not respond other times. We have tried resetting the controller, but still having issues.
Did you try adding logs to where the Input gets triggered? What type of input logic are you using on your Controller? Have you made sure that only a single instance of your input class is present inside of your application?
