Device Bridge for Secondary User not working
I faced an issue with ML Hub Device Bridge today. I enabled multi-user, switch to the secondary user and made some screenshot.
I wanted to download those on my computer through Device Bridge, but the file explorer only shows data for the Owner and not the Secondary user.
Anything I missed there ?
As a workaround, I used an USB-C stick and was able to copy the screenshots there :slight_smile:
Hi @alan.birchmeier,
Thank you for reaching out regarding this issue. Could you please provide a few more details to help solve your issue?
Are you running the ML Hub on a MacOS or Windows device?
What version of the ML Hub are you using?
What version of the Magic Leap 2 OS are you running?
Hi @etucker
Here are more details:
  • Windows 11 Business 23H2 (OS Build 22631.3737)
  • Magic Leap HubVersion 2.0.19.202405162050
  • ML OS Version 1.7.0
    Build B3E.240418.09-R.060
    Android API Level 29
Cheers
Apologies for the delay in response. Check out the ML Hub 3. You should be able to use device bridge for secondary users here.
