Wi-Fi bridge not turning on
Following the instructions https://developer-docs.magicleap.cloud/docs/guides/developer-tools/ml-hub/ml-hub-device-stream, I'm trying to turn on the stream via wifi, but the Wi-Fi bridge does not turn on, help solve the problem
P.S. Both my device and my development machine are on the same Wi-Fi network.
ML2 OS version- Version 1.4.0-dev1
Build B3E.230810.09-R.028
Android API Level 29
The error does not appear
Does the same behavior occur if you unplug the device via USB?
Can't start streaming via USB
The stream works periodically, but I don’t find any patterns
Hi @anddimovski,
I have reached out to our team regarding this issue and will keep you updated as soon as I hear back.
Hi @anddimovski,
Would you mind creating a bug report on the Magic Leap Hub?
