ZI targetviewcontroller stuck in paint->repaint->paint loop
As title says - when opening the unity editor it became stuck.
Unity Editor version (if applicable):
2022.2.0b4
MLSDK version:
0.53.2
Zero Iteration Module:
3.3.0.20220729
Zero Iteration Frontend version (ZIF, if applicable):
0.53.2
@TheMunk Can you provide any more information? Which OS are you running?
Windows 10.
When starting up the editor it works fine until I tried clicking the ZI device window (in order to right-click close the tab).
Had to revert layout to default/remove the package to get around it.
