Application Simulator cannot always be terminated
After starting in the simulator, the exit screen to change the State from Conncted to Disconncted is displayed and does not exit forever.
Unity Editor version : 2022.3.11f1
ML2 OS version :1.4.0-dev2
MLSDK version :1.4.0-dev2 (Unity Package 1.11.0)
ML Hub version: 2.0.15.202309142014
Magic Leap Application Simulator (ZI) Runtime version:v3.7.0.20230919
Magic Leap App Simulator for Unity (if applicable):v3.7.0.20230919
Host OS: (Windows/MacOS):Windows 11
Magic Leap Application Simulator Module Version 3.7.0.202309190301
Power and Thermal Profiler Module Version 2.0.0.202309142019
Magic Leap Application Simulator Runtime Version 3.7.0.20230919
Server: 3.7 (built Sep 19 2023), Protocol: 24
ZIF (bundled): Version 0.0.34.20230919
ZIF (runtime): Version 0.0.34.20230919
Please do not submit without first getting a ZIP of your logs from:
MLHubLogs-20231026-154024-win.zip (291.9 KB)
https://developer-docs.magicleap.cloud/docs/guides/developer-tools/ml-hub/app-sim/error-reporting
Don’t forget to attach the logs!
Hi @tokufxug,
I will go ahead and report this bug for you. About how often would you say this error happens for you?
I have never been able to exit successfully since updating to the latest version. Once I start the simulator, I have no choice but to force close it because it always happens.
