Unity MRTK 1.11.0 and SDK 1.4.0-dev2?
1 real problem blocking me, and 1 bother, getting our software working on ML2. The 1.0.0.5 version of the ML MRTK3 broke our work last week, I did not at the time notice that 1.11 was also released until this morning. Unfortunately, as you can see in the screenshot below, one of its dependencies is SDK version 1.4.0-dev2 which I cannot find anywhere.
The bother is that for some reason 1.11 is in the Unity section but 1.10 is in the Packages section. Which is probably why I did not notice the update.
2022.2.13:
1.4.0-dev1:
need 1.4.0-dev2:
**Windows
Thanks, I see the package manager versions were updated. I appreciate the quick turnaround.
