Unity Editor version: 2022.02
ML2 OS version: 1.4.0
Unity SDK version: 1.5.0
Hello I am trying to augment a long wall but the end of the wall gets cut off in the corners on the right and the left. What i want to see is a long wall when I turn my head but all I can see is the wall getting cut off. The wall is a 3d modeling in fbx.
What I tried to do is changing the field of view and clipping planes and occlusion culling. None of them has done any change.
Would you comment on this issue?
