ML_20240111_17.45.58.zip (18.1 MB)
The attached zip file is a video clip of how the cursor moves left to right. Oddly if the user moves their head right the cursor moves right then left in a repeating pattern and if the user moved their head left the cursor also moves right then left. A similar pattern happens with up and down head movement. While the head movement is a bit obnoxious to my boss, I think if the cursor moved with the direction of the head, I could sell it as a micro adjustment.
I have the MRTK3 sample compiled to use as a reference, and it does the exact same thing.
Does anyone have a fix for this? I have been looking into coming up with some solution but these issues seem to be on a fundamental level of the input system.
2022.3.13f1:
1.4.1:
1.4.0:
Windows 11: (Windows/MacOS)
MKTK3 Package 1.0.0 pre - 5
