MLZIPermissionsIsGranted Unspecified Failure
Unity Editor version: 2022.2.0b13.112.4548
ML2 OS version:Build: B3E.220818.12-R.046-R.417
SDK Version 29
MLSDK version: 29
Host OS: (Windows/MacOS) Windows.
I am building the media player example and was able to run with the default videos. When I changed the videos once, the changes did not get reflected in the device. Then I reverted the changes to original video source, and since then I am getting this error in the unity editor. Any insight on this? Now I cannot get a clean build running on the sample code at all.
-A
Error: MLZIPermissionsIsGranted in the Magic Leap API failed. Reason: MLResult_UnspecifiedFailure
UnityEngine.XR.MagicLeap.MLDevice:Update () (at Packages/com.magicleap.unitysdk/Runtime/Common/Utils/MLDevice.cs:450)
Hi @signashishup, Looking into this and will report back asap. Thanks for your post.
Hi @signashishup I spoke with our engineers and unfortunately the ML Video Player is not supported in the App Simulator.
