I have attached an Interface inside the ML Camera Object Prefab and thought ist would render totally perfect. If I move my head there is a little lag, offset and flickering what Looks like the Camera object rotation is set to the last rendered frame, not the cuttend rotation? How can I attachean object to the Camera view, so it‘s totally 100% stable in front of you each rendered frame?
@pepone the jittering that you are experiencing is due the time-warp processing that occurs on the headset to make sure 3d content appears stable. Although it improves the stability of content placed in the world, content may appear to jitter if it’s parented to the user’s head. To reduces this, developers can do the following:
If your application relies on content that is rigidly parented to the headset, you can disable time-warp processing by enabling headlock mode inside Magic Leap’s XR settings in you Project Settings.
You can use a script to position the content in instead of rigidly parenting the content to the user’s headset.
Thanks. Still insecure, when and where to grab the data. So the tracked pose driver push itself in location/rotaion before render. So how do I grab it's rotation/ position that millisecond and manually place my GUI there?
