Hand Tracking and Gesture Sensitivity on ML2 using MRTK3
I am currently developing an app for Magic Leap 2 using MRTK3, and I am experiencing issues related to hand tracking sensitivity, specifically noticed when doing pinch (air tap) gestures.
In my application, the hand ray appears to be overly sensitive. When I perform a pinch gesture, the hand ray shifts noticeably, often making it difficult or impossible to accurately select the intended target. This behavior becomes even more problematic as the distance between the user and the selectable object increases, since small hand movements result in large ray deviations.
I am trying to understand whether this behavior can be configured, mitigated, or corrected in Unity. Are there any parameters, interaction profiles, or recommended approaches to reduce hand ray instability or improve pinch gesture hand ray precision when interacting with distant objects?
What I find particularly interesting is that this issue does not occur when interacting with the Magic Leap 2 system UI itself. In the system experience, hand tracking and pinch interactions feel very precise and stable, which suggests that the hardware is capable of more accurate tracking than what I am currently achieving in my application.
Any guidance, best practices, or pointers to relevant settings or documentation would be greatly appreciated.
Another thing i noticed is that when doing pinch gesture to grab an object, its really hard to be able to position this object in a specific position (with good accuracy). For a few seconds after the user stops doing the pinch gesture, the device still thinks that the object is being manipulated. The only way to precisly position the object is for the user to carefully distantiate the fingers without moving its hand, so that the device understands that the user is not doing the pinch gesture anymore. Is there a way to also adjust pinch sensibility?
@jose.rocha
Please try the Line of Sight hand ray pose source (LOSAngularOffsetHandRayPoseSource) for your hand rays to see if it mitigates the issues you are seeing. This hand ray pose source should have similar behavior to the system UI hand ray.
See this post of the feature and how to set it up here: Add alternative LOSAngularOffsetHandRayPoseSource by whebertML · Pull Request #625 · MixedRealityToolkit/MixedRealityToolkit-Unity · GitHub
