Okay, recently, the controller just always disconnects on it’s own. It appears connected, but doesn’t work!
This is new. It wastes so much time.
Often, I can shut the controller off and turn it back on and it will fix it, but sometimes thats not good enough, and I need to restart the headset. Colossal waste of time.
This is only recent. I haven’t used this device for a year, so I assume its a recent OS update causing it. How can i diagnose this or fix this?
I mean, this is simple. The controller should work.
Thank you,
-Brandon
Do you notice this issue on the home menu or only inside of an application? Have you tried to adjust the standby setting inside the Settings > Battery?
I will try the standby setting when I get back to this.
It seems to be caused by a performance overload. The app I am working with can cause extreme lag. It’s not a complete app and this is unintended of course, but at some point, this causes the controller to disconnect. The tracking does not show in the app or home menu. I can get home by the wrist shortcut.
It’s almost like there is an overload that causes some form of tracking or controller connection thread or something along those lines to stall or crash.
Sometimes it can come back by simply waiting, (too long) but this is very rare. It’s not consistent, some times I’ve waited a literal 5 minutes to see if waiting is viable. It’s not.
Restarting the controller fixes it 9/10 of times.
That last 1/10 times requires a full system restart.
Controller standby was and is off, still occurs nearly every session of testing my app
