We bought Magic Leap a few months ago. The OS version on ML2 is 1.12, and controller version is up to date (glasses says no update needed). But ML Controller very frequently stops working after sometimes and there is no way to fix, until Magic Leap is restarted again. This happens extremely frequent. We are developing Unity apps and Controller works in Unity Applications all the time, never have a problem, even several times we restart Unity apps, they all work. But when you close the Unity application, sometimes main menu of Magic Leap does not work with controller anymore, controller is not correctly tracked, and I have to use hands only afterwards. In main menu, controller tracks position but direction is incorrect and trigger button do not work, but Home button works. But when I start Unity application controller starts working, when I shut down Unity application, controller stops working. I could not find out the problem, but this really seems to be an OS bug since main menu is not working, but applications works.
Hmm, we are not tracking this type of bug on our side. Lets see if we can sort it out.
Do you notice this behavior after using any application or specifically your application or the Unity Example project? Does your application use the World Cameras / Pixel Sensor?
Does the issue occur even when the hand input is disabled in the System Settings?
Have you tried Resetting your device and reinstalling the latest OS?
When the device first open, there is no problem. When we start/stop our application, it still works sometime. But after some time, controller stops working when we go out of our app, but I don't know when and why. We don't use other apps so long to test if it fails with other applications or not. But this problem continues till we get it, it did not happen later on, we did not reset but I updated OS about 3 times till now. Nothing changed in each update.
The important point may be we currently use non-OpenXR sdk since Vuforia does not work with OpenXR sdk. May be Main Menu has problems switching between legacy and new SDK. But as I remember (not sure), this problem was still there when we were using OpenXR sdk also. But in any way, an application should not be able to make the OS fail.
In source code:
private InputAction XRTriggerInputAction = new InputAction(binding: "/trigger", expectedControlType: "Button");
In start we get actions like that
if (XRTriggerInputAction != null)
XRTriggerInputAction.Enable();
mMagicLeapInputs = new MagicLeapInputs();
mMagicLeapInputs.Enable();
mControllerActions = new
MagicLeapInputs.ControllerActions(mMagicLeapInputs);
In OnApplicationQuit we dispose like that:
XRTriggerInputAction.Dispose();
mMagicLeapInputs.Dispose();
Unfortunately, our options to debug this are limited unless we have reproduction steps. Maybe there are a series of steps that we can test based on the older Magic Leap Example project ? Have you been able to reproduce this when running the default 1.12.0 Unity Example project ?
Hey cagatay, I got the exact same issue. I’m using the Unity new input system and OpenXR SDK(Magic Leap2) version, the controller works when the apk launched for the first time, but the controller will lose the function after a while or leave the app and come back again. The controller still works outside the apk, and works well in any other apk. I have to reboot the ML2 to get the controller work again in my apk.
@jojo , Are you building a new App or using the Unity Examples? Which version of the OS and SDK are you using? Can you make sure that Magic Leap OpenXR is the only Plug-in provider selected in the Project Settings?
Indead my problem is reversed. Controller always works in my applications. It stops working when exit to magic leap 2 main menu sometimes. When it stops working it never works again in ML2 menu but it still works in my application. Not solved yet. Problem seems to be with OS, since my application works correctly, OS not work.
