Compute Pack LED Guide missing info
Our compute pack is blinking thrice with all 5 LED's - like the "thermal warning" in the guide - but white.
It is not covered in the guide;
What does this mean?
Hi there @TheMunk, thank you for pointing that out. I'll run that down on my side. In the meantime, can you tell me if it looks like the "Charging Complete" pattern here? MagicLeap Developer Documentation
Hey @TheMunk, thanks for the feedback.
Can you clarify what you were doing with your device when you saw the LED pattern in question? And to confirm the LED behavior you're seeing: you say it look like the hardware failure LED pattern, only white instead of red - so you see the rightmost three white dots blinking?
I've come to guess it means "full power". But it's much faster than what the documentation shows.
Ah, yes I misread your initial post - it does sound like the charging complete LED pattern. Working on getting that back on the Care article in question.
