Application Simulator Crashing
Give us as much detail as possible regarding the issue you’re experiencing.
Hello, I am trying to use the application simulator but every time I start the simulator the magic leap hub will close. I was wondering if this feature was still supported or if there are alternatives to the application simulator with the new hub. I am unable to get the logs because that requires the application simulator to open.
Unity Editor version (if applicable):
ML2 OS version:
MLSDK version: 1.9.0 / 1.6.0
ML Hub version: 2 simply because 3 does not seem to have the application simulator
Magic Leap Application Simulator (ZI) Runtime version: 3.9.0.20240312
Magic Leap App Simulator for Unity (if applicable):
Please do not submit without first getting a ZIP of your logs from:
https://developer-docs.magicleap.cloud/docs/guides/developer-tools/ml-hub/app-sim/error-reporting
Don’t forget to attach the logs!
You can capture the logs after the MLHub closes. You can also try using the Unity App Simulator integration :Application Simulator Plug-in for Unity Editor | MagicLeap Developer Documentation
Unfortunately, on-going support for App Simulator is limited as the tool has been deprecated since OS version 1.5.0 . We recommend using OpenXR and the XRI simulator inside Unity.
