Webrtc sample
Hi I am unable to find the Webrtc samples as mentioned in the
WebRTC | MagicLeap Developer Documentation
Was it still available or deprecated ?
Unity Editor version:
ML2 OS version:
Unity SDK version:
Host OS: (Windows/MacOS)
Hi @kpradp,
We are looking to release a new WebRTC sample project in the near future. Our MLSDK Implementation is currently being looked at as there were some issues with connecting. We do recommend, if possible to use Unity's WebRTC package.
https://docs.unity3d.com/Packages/com.unity.webrtc@2.4/manual/index.html
Ok
Can you provide me the old sample repo. I need some reference for the server implementation to work with unity webrtc package
The MLWebRTC sample can be found in the ML Hub under the Package Manager.
