We have a USB flight controller we'd love to be able to use with the ML2 and Unity. Is there a way to do this? I'm not sure if connecting the controller directly to the ML2 would work, and if not is it possible to remote render using Unity? That way the PC could handle the flight controller. Any suggestions would be greatly appreciated. Thanks!
Hi @rob42lou,
Thank you for raising this question. I've reached out to our team to see what is possible using an external controller.
If the flight controller is compatible with Android, it should work with the ML2. One thing to keep note of is that you will not be able to restore power to the ML2 while using it.
What is it that you are trying to remote render?
Additionally, while it is not officially supported, there are many USB-C hubs that support USB-PD (USB Power Delivery) which will allow you to power the ML2 while using your controller.
