Connecting ML2 Unity project with cloud
Hallo dear ML Forum team,
so I've been trying to connect ML2 through unity project to a cloud cause there are some PDFs I'd like to access and open within Unity. But I can't seem to find a way to get the headset to go into the cloud / remote storage, has maybe perhaps you're team found a way. There must be I am just not looking in the right place. Any help would be greatly appreciated.
Thanks up front !
Unity Editor version:
ML2 OS version:
MLSDK version:
Host OS: (Windows/MacOS)
Hi @a.reality, It all depends on the Unity SDK integration of the cloud solution you're using. Anything that works on Android will work on Magic Leap 2. Let me know if you run into trouble.
