Hi, could you please clarify some things regarding updating the OS.
The documentation clearly states that you should update in a linear fashion which I understand to mean installing every version from the version you have to the latest. Is this really the case? The ML Hub OS Installer is quite happy to let you install the latest version, jumping previous versions.
Since V1.0.0 the 'B3E' version numbers are not shown in the ML Hub OS Installer drop down list of available versions so how do you know which version you have?
So for example if I have a headset with 1.0.0 (B3E-220818.12-R.046_user_secure) would I be expected to install all the OS's in this order?
1.1.0-dev1
1.1.0-dev2
1.1
1.2.0-dev1
1.2.0-dev2
i.e. 5 updates?
I'm also confused about the whole Secure/Unsecure difference. The Part Number on my headset says it's an Unsecure (as the part number ends in 'RG' but ML Hub only lets me install the Secure versions.
Thanks
