Unity Sample Project for Model Target using Vuforia Engine
Dear All,
Do any of you have a Unity sample project for Model Target using the Vuforia Engine? I am new to Unity development, so if anyone has worked on this before, I would greatly appreciate it if you could share it with me.I am planning to develop a model target application for Magic Leap 2.
Thank you!
Hi @acharya,
Check out this getting started guide on the Vuforia website. It should have everything you need to get a project up and running. Let me know if you have any questions or run into any issues.
Hi @etucker
Thank you for providing the reference.
For Image target, the provided link is sufficient to develop the app.
I have model target (generated by using Vuforia Engine-vuforia target generator) with type standard target. I want to overlay the 3d model on top of the physical model with the help of vuforia model target.
It would be helpful if you explain the complete process in details.
I recommend reaching out to Vuforia's support team here. Support | Vuforia Library
They should be able to better assist you with details.
