The Lab 2.0 Installation Error
I'm running Windows 10 Version 21H2 for x64. I downloaded the lab installer:
https://developer.magicleap.cloud/downloads
Upon opening it, I see the following installation error
labInstallerFailed
Hi Alex,
We're looking into this and will get back to you with a solution asap.
@alex This looks like something is hijacking your download, likely malware or virus. Your downloaded file should JUST be a .exe file.
If you can, please run a virus scan and report the results. This will help us identify the issue.
Issue identified:
No viruses, I figured out it was just an issue with Firefox. When you download from firefox it appends a .vbs extension to the existing .exe. Chrome downloads it as a .exe
@alex
You may still want to double check your Firefox configuration to be on the safe side (extensions/plugins/etc): fresh install of Firefox 104.0 downloads Lab installer as EXE file and does not append VBS extension on my setup (Windows 10).
