Unity Editor version: 2022.3.5
ML2 OS version:
MLSDK version: 1.9.0
Hello Magic Leap community,
I'm currently working on a project where I'm trying to stream video from my Magic Leap 2 device to a Unity PC application using WebRTC. I've successfully established a connection, and the audio streams perfectly from the Magic Leap device. However, I'm facing an issue with the video stream.
Problem: Once the connection is made, the video on the Unity side only displays the first frame and then freezes. The audio continues to stream without any issues.
Setup:
- Magic Leap 2: I'm using the default settings and, as far as I know, I can't change or select the codec when sending video from this side.
- Unity PC App: I'm utilizing the Unity WebRTC package. This package supports:
- Hardware decoding of video in H264 format.
- Software decoding of video in VP8 and VP9 formats.
Given that I can't select the codec on the Magic Leap side, I suspect there might be a compatibility issue with the video codec being used by Magic Leap 2 and the decoding capabilities of the Unity WebRTC package.
Request for Help:
- Has anyone faced a similar issue when streaming video from Magic Leap to another platform via WebRTC?
- Is there a way to change or select the video codec on the Magic Leap side, even if it's not directly exposed in the settings?
- Are there any recommended settings or workarounds to ensure smooth video streaming between Magic Leap 2 and Unity using WebRTC?
Any insights, suggestions, or solutions would be greatly appreciated. Thank you in advance for your assistance!
