screen recording problem in unity app
When I do screen record in ML with Unity build, I see an overlay like shadow, it reflects back to my MR objects. Does anyone have info on this or ever screen recording on ML?
Unity Editor version: 2022.2.5f1
ML2 OS version:1.1.0
MLSDK version:1.2.0
Host OS: (Windows/MacOS)
Hi @mdtien.ict ,
Can you provide a device screenshot or video recording that demonstrates what you're seeing?
@mdtien.ict It's likely either one of these issues, plz fix it magic leap <3
this is what i'm seeing. Have you ever encountered this problem?
yeah, thank you for the info
Can you try updating to a newer Unity version and updating your SDK and your OS to the latest version?
