Remote rendering does not work as the above pop-up appears.
- 'service-start' command failed with 8 and said:
SvcEnum::SvcEnum: EnumServicesStatusExA failed 8
(I'm working on a different computer, so my current question is unrelated to my past posts)
Can you try uninstalling Magic Leap remote rendering from the standard windows Add/Remove Programs and reinstall it. Open the ML Hub as administrator before trying to reinstall.
If the service still fails, could you capture the logs from the Magic Leap Hub?
MLHubLogs-20240216-101000-win.zip (20.9 KB)
I've tried as you told me, but it still fails with the same pop up
