we are trying to use multiview rendering to render image for both eyes in single pass, it requires
support for OpenGL ES extension GL_OVR_multiview, which is supported by ML2
OpenXR swapchain with texture array, unfortunately attempt to create one fails:
XrSwapchain swapchain;
XrSwapchainCreateInfo swapchainCreateInfo{ XR_TYPE_SWAPCHAIN_CREATE_INFO };
swapchainCreateInfo.arraySize = 2;
CHECK_XR_RESULT(xrCreateSwapchain(session, &swapchainCreateInfo, &swapchain)); // fails
Is there any other way to make it working?
v1.3.0-dev2, 1.3.1 OS
Best regards,
Ernest
Hi @emikita,
Regarding your issue with OpenXR swapchain with texture array, I've reached out to our team to see if there are any possible fixes for your issue. May I ask, are you receiving any error logs?
Hi @emikita,
In addition to any logs, could you please share the result code that you get back from the call to xrCreateSwapchain? It should be in the exception thrown by CHECK_XR_RESULT. Could you also please share the complete contents of your XrSwapchainCreateInfo struct?
Thanks!
Adam
swapchainCreateInfo.usageFlags = XR_SWAPCHAIN_USAGE_SAMPLED_BIT | XR_SWAPCHAIN_USAGE_COLOR_ATTACHMENT_BIT;
swapchainCreateInfo.format=GL_RGBA8;
swapchainCreateInfo.sampleCount=1
swapchainCreateInfo.arraySize=2
swapchainCreateInfo.faceCount=1
swapchainCreateInfo.mipCount=1
swapchainCreateInfo.width=1440
swapchainCreateInfo.height=1760
CHECK_XR_RESULT(xrCreateSwapchain(session, &swapchainCreateInfo, &swapchain)); // XR error: -2 (XR_ERROR_RUNTIME_FAILURE)
// it works with swapchainCreateInfo.arraySize=1
Hi @emikita,
I wanted to give you an update and let you know that we are actively working on this issue. Also, multiview rendering may not give the performance enhancement you may be expecting on our platform if that is your ultimate goal.
