MRTK Project Configuration Question
In the instructions for MRTK (Set Up MRTK for Magic Leap 2 | MagicLeap Developer Documentation), there are some unclear steps:
  1. Install Universal RP from the Package Manager and set a UniversalRenderPipelineAsset in the Graphics Settings
Under what menu is "Graphics Settings"?
  1. Make sure Custom Main Manifest is selected under Publishing Settings so MagicLeap Manifest Settings can be set.
Under what menu is "Publishing Settings"?
Thank you.
hi @paklnet Publishing Settings are in Edit > Project Settings > Player > Publishing Settings
The Graphics Settings are in Edit > Project Settings > Graphics
