Massive frame rate drop when capturing an image
Hey all,
My app uses the image capture abilities pretty frequently. I only take still images, not using video or anything.
When capturing an image I experience severe framerate drop (from 60 fps to about 10).
My image capture logic is mostly built around the example scene. I think I may not get it all the way through tough.
this is the method that captures the image
 public override void StartCapture()
     if (CanCapture())
         _isCapturing = true;
         _imageCapturedThisPress = false;
         // Initialize CaptureConfig
         Debug.Log("Stream capabilities initialized");
         MLCamera.StreamCapability selectedCapability = _targetStreamCapability;
         MLCamera.CaptureConfig captureConfig = new MLCamera.CaptureConfig
             CaptureFrameRate = frameRate,
             StreamConfigs = new MLCamera.CaptureStreamConfig[1] { MLCamera.CaptureStreamConfig.Create(selectedCapability, OutputFormat.JPEG) }
         // Prepare for capture
         Debug.Log("Prepare Capture");
         MLResult result = _captureCamera.PrepareCapture(captureConfig, out MLCamera.Metadata _);
         if (MLResult.DidNativeCallSucceed(result.Result, nameof(_captureCamera.PrepareCapture)))
             // Trigger auto-exposure and auto-white-balance convergence
             Debug.Log("Trigger auto-exposure and auto-white-balance convergence");
             _captureCamera.PreCaptureAEAWB();
         else
             Debug.Log("pre capture failed");
             // Failed to prepare the camera
         // Capture the image
         Debug.Log("Capture");
         _captureCamera.CaptureImage();
         onCaptureStarted?.Invoke();
         if (!result.IsOk)
             Debug.Log(" Image capture failed " + result);
and this is method caled when image was captured
 private void OnCaptureRawImageComplete(MLCamera.CameraOutput output, MLCamera.ResultExtras resultExtras,
     MLCamera.Metadata metadataHandle)
     if (output.Format != MLCamera.OutputFormat.YUV_420_888)
         try
             _latestCaptureData = ImageConvertor.ConvertBytesToJpegTexture(output.Planes[0].Data, output.ToString());
             _imageCapturedThisPress = true;
             if (streamToDisplay) imageDisplay.DisplayCapture(_latestCaptureData);
         catch (Exception e)
             Debug.LogError(e.Message);
         finally
             _isCapturing = false;
Unity Editor version: 2022.3.16f1
ML2 OS version:1.4.0-dev2
Unity SDK version: 1.12
Sorry to hear that you are experiencing this issue. Based on your code, I recommend updating it to use the Capture Async method instead to prevent the function from blocking the main thread.
