I have experienced with my app using vuforia appears to be hanged a few seconds after launch. The imagetarget gets recognized and then all the prefabs I enabled disappeared, and only randomly would they re-appear for a second in uncertain periods.
I opened a brand new project, set up ML and Vuforia, created an ImageTarget from a image, and attached a script component for capturing camera image and then the app malfunctioned. See below for the camera capture code. Once I added the camera component to the app then every following build w/ or w/o the camera script components enabled would result in the same behavior that I mentioned earlier (the text mesh disapperas, image target is not recognized, but the text might randomly appear for a sec once for around 20s). Only a full restart of ML & my PC, and wiping out the app & apk file could solve the issue, but it comes again after I enable the camera code.Following that I tried delayed initialization of Vuforia with the following script:
using System.Collections;
using Vuforia;
public class Test : MonoBehaviour
    void Start()
        VuforiaApplication.Instance.Initialize();
        GameObject.Find("Main Camera").GetComponent<VuforiaBehaviour>().enabled = true;
        // hard_1417 is the object name of the image target.
        GameObject.Find("hard_1417").GetComponent<ImageTargetBehaviour>().enabled = true;
    // Update is called once per frame
    void Update()
and surprisingly the app starts to hang and fails to work properly. I'm reading something like this in the bug report:
08-17 16:46:28.602770  8644  8661 E BufferQueueConsumer: [BufferItemQueue] acquireBuffer: max acquired buffer count reached: 5 (max 4)
08-17 16:46:28.602821  8644  8661 E BufferItemConsumer: [BufferItemQueue] Error acquiring buffer: Unknown error -38 (-38)
08-17 16:46:28.602831  8644  8661 E         : acquireBuffer BufferItemConsumer::acquireBuffer fail, status: -38
08-17 16:46:28.618019  3458  3936 I cvip-ch : Aug 17 20:46:19 0000010579345477491 ARM.05 00961 me_38a8bcb4da05 [algo/arm/src/wr_arm_blocks.cpp:00366]:I:: :wr: Reconstructing depth frame 6385/6385, 4926330299us
but I'm not sure if that's related with the problem I had. I'm using Version 1.3.1, Build B3E.230616.02-R.121, Android API Level 29 and I'm using ml sdk 1.3.0 and unity package 1.9.0. Also I'm using Vuforia 10.16.5.
If there's nothing wrong, should I reset magic leap just to make sure nothing is wrong on that side?
Thanks in advance!
For Camera Capture:
using System;
using Vuforia;
public class NewCamera : MonoBehaviour
    [SerializeField, Tooltip("Desired width for the camera capture")]
    private int captureWidth = 1280;
    [SerializeField, Tooltip("Desired height for the camera capture")]
    private int captureHeight = 720;
    //Not used in this example
    //  [SerializeField, Tooltip("The renderer to show the camera capture on RGB format")]
    //  private Renderer _screenRendererRGB = null;
    //The identifier can either target the Main or CV cameras.
    private MLCamera.Identifier _identifier = MLCamera.Identifier.Main;
    private MLCamera _camera;
    //Is true if the camera is ready to be connected.
    private bool _cameraDeviceAvailable;
    private MLCamera.CaptureConfig _captureConfig;
    private Texture2D _videoTextureRgb;
    //The camera capture state
    bool _isCapturing;
    private MLCamera.CameraOutput _lastCameraOutput;
    private MLCamera.ResultExtras _lastExtras;
    private Matrix4x4 _lastTransform;
    private bool permissionCameraGranted = false;
    private void Awake()
    private void OnDestroy()
    void Start()
        MLPermissions.RequestPermission(MLPermission.Camera, permissionCallbacks);
        MLPermissions.RequestPermission(MLPermission.SpatialMapping, permissionCallbacks);
        MLPermissions.RequestPermission(MLPermission.SpatialAnchors, permissionCallbacks);
        StartCoroutine(EnableMLCamera());
        permissionCameraGranted = true;
        Debug.Log($"{permission} granted.");
    void OnDisable()
        StopCapture();
    //Waits for the camera to be ready and then connects to it.
        while (!permissionCameraGranted)
            yield return null;
        // VuforiaApplication.Instance.Initialize();
        // GameObject.Find("Main Camera").GetComponent<VuforiaBehaviour>().enabled = true;
        // GameObject.Find("hard_1417").GetComponent<ImageTargetBehaviour>().enabled = true;
        yield return new WaitForSeconds(5);
        //Checks the main camera's availability.
        while (!_cameraDeviceAvailable)
            MLResult result = MLCamera.GetDeviceAvailabilityStatus(_identifier, out _cameraDeviceAvailable);
            if (result.IsOk == false || _cameraDeviceAvailable == false)
        yield return ConnectCamera();
    private IEnumerator ConnectCamera()
        //Once the camera is available, we can connect to it.
        if (_cameraDeviceAvailable)
            MLCamera.ConnectContext connectContext = MLCamera.ConnectContext.Create();
            connectContext.CamId = _identifier;
            //MLCamera.Identifier.Main is the only camera that can access the virtual and mixed reality flags
            connectContext.Flags = MLCamera.ConnectFlag.CamOnly;
            var createAndConnectAsync = MLCamera.CreateAndConnectAsync(connectContext);
            while (!createAndConnectAsync.IsCompleted)
                yield return null;
            _camera = createAndConnectAsync.Result;
            if (_camera != null)
                Debug.Log("Camera device connected");
                if (TryGetCaptureConfig(out _captureConfig))
                    Debug.Log("Camera Config Created. Starting Video Capture");
                    yield return StartVideoCapture();
                else
                    Debug.LogError("Cannot Create Capture Config");
                    yield break;
        yield return null;
    private bool TryGetCaptureConfig(out MLCameraBase.CaptureConfig captureConfig)
        captureConfig = new MLCameraBase.CaptureConfig();
        //Gets the stream capabilities the selected camera. (Supported capture types, formats and resolutions)
        MLCamera.StreamCapability[] streamCapabilities = MLCamera.GetImageStreamCapabilitiesForCamera(_camera, MLCamera.CaptureType.Video);
        if (streamCapabilities.Length == 0)
            return false;
        //Set the default capability stream
        MLCamera.StreamCapability defaultCapability = streamCapabilities[0];
        //Try to get the stream that most closely matches the target width and height
        if (MLCamera.TryGetBestFitStreamCapabilityFromCollection(streamCapabilities, captureWidth, captureHeight,
                MLCamera.CaptureType.Video, out MLCamera.StreamCapability selectedCapability))
            defaultCapability = selectedCapability;
        //Initialize a new capture config.
        captureConfig = new MLCamera.CaptureConfig();
        //Set RGBA video as the output
        MLCamera.OutputFormat outputFormat = MLCamera.OutputFormat.RGBA_8888;
        //Set the Frame Rate to 30fps
        captureConfig.CaptureFrameRate = MLCamera.CaptureFrameRate._30FPS;
        //Initialize a camera stream config.
        //The Main Camera can support up to two stream configurations
        captureConfig.StreamConfigs = new MLCamera.CaptureStreamConfig[1];
        captureConfig.StreamConfigs[0] = MLCamera.CaptureStreamConfig.Create(defaultCapability, outputFormat);
        return true;
    private IEnumerator StartVideoCapture()
        MLResult result = _camera.PrepareCapture(_captureConfig, out MLCamera.Metadata metaData);
        if (result.IsOk)
            //Assume this is done by Vuforia
            // _camera.PreCaptureAEAWB();
            //Images capture uses the CaptureImage function instead.
            var captureVideoStartAsync = _camera.CaptureVideoStartAsync();
            while (!captureVideoStartAsync.IsCompleted)
                yield return null;
            result = captureVideoStartAsync.Result;
            _isCapturing = MLResult.DidNativeCallSucceed(result.Result, nameof(_camera.CaptureVideoStart));
            if (_isCapturing)
                Debug.Log("Video capture started!");
                _camera.OnRawVideoFrameAvailable += RawVideoFrameAvailable;
            else
                Debug.LogError($"Could not start camera capture. Result : {result}");
    private void StopCapture()
        if (_isCapturing)
            _camera.CaptureVideoStop();
            _camera.OnRawVideoFrameAvailable -= RawVideoFrameAvailable;
        _camera?.Disconnect();
        _isCapturing = false;
    void RawVideoFrameAvailable(MLCamera.CameraOutput output, MLCamera.ResultExtras extras, MLCameraBase.Metadata metadataHandle)
        _lastCameraOutput = output;
        _lastExtras = extras;
        if (MLCVCamera.GetFramePose(extras.VCamTimestamp, out Matrix4x4 cameraTransform).IsOk)
            _lastTransform = cameraTransform;
        //Additional logic to render the image
        // if (output.Format == MLCamera.OutputFormat.RGBA_8888)
        //     UpdateRGBTexture(ref _videoTextureRgb, output.Planes[0], _screenRendererRGB);
    public Vector2 WorldPointToPixel(Vector3 worldPoint)
        if (_lastExtras.Intrinsics.HasValue)
            int width = (int)_lastCameraOutput.Planes[0].Width;
            int height = (int)_lastCameraOutput.Planes[0].Height;
            return WorldPointToPixel(worldPoint, width, height, _lastExtras.Intrinsics.Value, _lastTransform);
        Debug.Log("No Intrinsic value");
        return new Vector2(0, 0);
    private Vector2 WorldPointToPixel(Vector3 worldPoint, int width, int height, MLCameraBase.IntrinsicCalibrationParameters parameters, Matrix4x4 cameraTransformationMatrix)
        // Step 1: Convert the world space point to camera space
        Vector3 cameraSpacePoint = cameraTransformationMatrix.inverse.MultiplyPoint(worldPoint);
        // Step 2: Project the camera space point onto the normalized image plane
        Vector2 normalizedImagePoint = new Vector2(cameraSpacePoint.x / cameraSpacePoint.z, cameraSpacePoint.y / cameraSpacePoint.z);
        // Step 3: Adjust for FOV
        float verticalFOVRad = parameters.FOV * Mathf.Deg2Rad;
        float aspectRatio = width / (float)height;
        float horizontalFOVRad = 2 * Mathf.Atan(Mathf.Tan(verticalFOVRad / 2) * aspectRatio);
        normalizedImagePoint.x /= Mathf.Tan(horizontalFOVRad / 2);
        normalizedImagePoint.y /= Mathf.Tan(verticalFOVRad / 2);
        // Step 4: Convert normalized image coordinates to pixel coordinates
        Vector2 pixelPosition = new Vector2(
            normalizedImagePoint.x * width + parameters.PrincipalPoint.x,
            normalizedImagePoint.y * height + parameters.PrincipalPoint.y
        return pixelPosition;
    private void UpdateRGBTexture(ref Texture2D videoTextureRGB, MLCamera.PlaneInfo imagePlane, Renderer renderer)
        if (videoTextureRGB != null &&
            (videoTextureRGB.width != imagePlane.Width || videoTextureRGB.height != imagePlane.Height))
            Destroy(videoTextureRGB);
            videoTextureRGB = null;
        if (videoTextureRGB == null)
            videoTextureRGB = new Texture2D((int)imagePlane.Width, (int)imagePlane.Height, TextureFormat.RGBA32, false);
            videoTextureRGB.filterMode = FilterMode.Bilinear;
            Material material = renderer.material;
            material.mainTexture = videoTextureRGB;
            material.mainTextureScale = new Vector2(1.0f, -1.0f);
        int actualWidth = (int)(imagePlane.Width * imagePlane.PixelStride);
        if (imagePlane.Stride != actualWidth)
            var newTextureChannel = new byte[actualWidth * imagePlane.Height];
            for (int i = 0; i < imagePlane.Height; i++)
                Buffer.BlockCopy(imagePlane.Data, (int)(i * imagePlane.Stride), newTextureChannel, i * actualWidth, actualWidth);
            videoTextureRGB.LoadRawTextureData(newTextureChannel);
        else
            videoTextureRGB.LoadRawTextureData(imagePlane.Data);
        videoTextureRGB.Apply();
