Load Exported Spaces on PC
HI, I have a question about the exported space (map) from ML2. Is there a way to load the map on PC? If not, how can I make sure the created map has a satisfactory confidence level? If there is a way, can I edit the map on PC, for example, add the spatial anchors manually to the map so I don't need to use ML2 device to place them?
Hi @ineedhelpty,
I have reached out to our team to see what is possible regarding manipulating spaces that have been uploaded to a PC. I will get back to you as soon as I hear back.
Hi @ineedhelpty,
At this time, it is not possible to upload spaces to your PC and manipulate them. I will definitely log this feedback and I will keep you updated on any future developments in this vein.
