Unity Editor version 2022.3.47f1:
ML2 OS version: 1.12.0
MLSDK version: 2.6.0
Hi everyone,
I am developing an application for Magic Leap 2 where I scan the environment for planes using the sample scene provided. Once the plane detection is complete, I stop the scanning process and attempt to use raycasting to interact with the detected plane.
However, I am facing some issues:
- When using the controller pointer, it passes through the detected plane, making interaction difficult.
- If I enable a mesh, the pointer does not pass through, but I am unable to instantiate a sphere on the detected plane or mesh.
I would like guidance on how to correctly use raycasting to detect trackable planes and instantiate objects at the intersection point.
Here are my current SDK versions:
ML2SDK: 2.6.0
OpenXR: 1.13.0
AR Foundation: 5.1.6
Any insights or suggestions would be greatly appreciated!
Thanks in advance.
You may need to change the layer that the panes are on. You may also need to add a mesh collider to the plane.
Unfortunately, it’s hard to tell directly what might be happening. But we do have this guide that might be helpful.
I tried your approach, but it doesn’t seem to work. Let me explain my issue simply.
I am performing plane detection using the Magic Leap 2 sample project, and I can successfully see the detected planes. Now, I want to draw a rectangle on the detected plane using the controller. My approach is to cast four spheres on the plane and then use a Line Renderer to connect the points.
However, I am facing an issue with Raycasting in Magic Leap 2:
- I am unsure if I am correctly casting the ray using the trigger button.
- Even if the ray is being cast, the detected plane does not seem to recognize it.
I need your help to understand and resolve these issues. Could you guide me on how to properly perform raycasting on detected planes using the controller?
Looking forward to your response.
Does the plane have a mesh collider attached to it? Are you simply using physics raycast in Unity? Have you added logs ? (For example log when the raycast hit’s a collider)
Yes, the plane does have mesh collider attach to it. I make no changes to the sample from magic leap2 SDK. but still the pointer ray passes through the plane. Also I tried both methods, AR raycast and Physics Raycast, non of them works.
Hmm, it sounds like a tricky problem. Can you verify that you get the results you are expecting when using the physics raycast on a cube or other 3d mesh?
I have resolved the issue. I set up a new project and added the AR Raycast Manager, along with debug logs for troubleshooting. As a result, I can now see the detected plane.
Using the trigger button, I instantiate a sphere on the plane. However, the sphere does not align with the controller’s pointer; instead, it always spawns with an offset.
Below is the simple logic I used for raycasting:
void Update()
// Get the controller pointer position & rotation
Vector3 pointerPos = pointerPosition.action.ReadValue();
Quaternion pointerRot = pointerRotation.action.ReadValue();
Ray ray = new Ray(pointerPos, pointerRot * Vector3.forward);
// AR raycast
if (arRaycastManager.Raycast(ray, arHits, TrackableType.PlaneWithinPolygon))
Pose hitPose = arHits[0].pose;
// (Trigger Pressed)
if (triggerPressed.action.WasPressedThisFrame() && !shapeClosed)
PlacePoint(hitPose.position);
Could you help me understand why this offset occurs and how to properly align the sphere with the controller’s pointer?
