How to get pupil diameter from native API
Hi - there is mention in the docs and software licenses about accessing various eye metrics. Some of thee include pupil diameter. We can't seem to find any way to get the pupil size information from the native api. Can some please advise how we can do this?
Thank you!
Hi @jweatherhead Can you provide links to the documentation that mention this feature? Obtaining the Pupil Diameter is still in development and is not exposed in our APIs. Previous versions of our SDK might have had stub APIs for testing but they always returned 4mm.
From the December 2021 release:
The pupil diameter is calculated internally but in the API the connection is stubbed out and will always return 4mm.
Hi Krystian
Thanks so much for the info. Do you know when the true pupil measurement will be made available in the api?
One mwntion we found is in the following link where it eludes to the system collecting pupil size.
https://www.magicleap.com/eye-tracking
Thanks again for your help
Get Outlook for iOS
