Can I update the name of the "Owner" so the ML2 displays a username instead of the word "Owner" when prompting for the password (i.e. "Welcome back, wrichey" instead of "Welcome back, Owner"?
I'm currently using Magic Leap Hub 3 and ML2 software version 1.11.0. I do not see a User Profile anywhere in the settings.
You can create multiple profiles through the System Settings. However, Android 10 requires the Admin to login once after the device reboots before a user can select a different profile.
Thank you for this reply. Can you only add a username if there is more than one user? I do not want to create multiple profiles. I only wish to change the name of the admin user.
On my device there is one user and the username is "Owner". In the linked example the admin is "Cian". I don't believe I need any of the other features associated with a Developer Pro or Enterprise license. Do I need one of these licenses in order to change my admin username?
We use the same flow as Android 10, so to change the name of the Admin you would go to the device's Settings > System > Multiple users and then click "You (Owner)" to change the name.
The menu options under Settings>>System>>Advanced do not include "Multiple users" as pictured in the example.
The only options i see are Languages, Capture and Device Stream, Date & time, Reset options, Developer options, and OS Updater
Do I need to have a Developer Pro or Enterprise license in order to see the "multiple users" option?
I see, you are correct. However, this will not be the case in OS version 1.12.0.
Thank you. This question is solved with v1.12.
I followed the instructions for multiple users lined above ( Using Multiple User Profiles on Device ā Care | Magic Leap) and renamed the admin. Then, the "enable multiple users" toggle can be switched off and the admin name will remain.
