For technical reasons I usually connect to the ML2 via WiFi for deployment and downloading log files. Every time I have to enter the IP address. It's always the same here. Would it be possible to keep a short list of recently used IP addresses, with the last one used selected by default?
Hi! I'm going to go ahead and put in a Voice of Customer Ingest. Is this referring to entering the ip address on the ML Hub?
Correct. This thing
Is this something I can do myself, feature requests? I use the forums for it, but maybe that's not the right place
Yes, you can provide feedback directly on the /support section of the Developer Portal. Let me know if you run into any issues accessing the page.
https://ml2-developer.magicleap.com/support
